staggered offset/Rubbing
Old 09-28-2011 | 02:43 PM
SDgoods's Avatar
Default staggered offset/Rubbing
Hello!
I purchased an s2k a couple weeks ago and the previous owner told me the specs are 17x9.5 +28 Front and 17x9.5 +38 rear, 245/40/17 F+R
Also, the rears dont rub at all as im running a lot of neg camber (dont know the spec, but too much for my liking) and the fenders are rolled. however up front i have 30mm carbon over fenders and they rub on compression and hard cornering.
any suggestions?
Any input would be appreciated. Im new to tuning aggressive wheels/suspension as i had a non-wide/ high offset wheel and suspension setup on my subaru.
Attached Thumbnails staggered offset/Rubbing-img_5637.jpg
Old 09-28-2011 | 02:53 PM
ScandinavianFlick's Avatar
Stock offsets are +55F/+65R. Those wheels are
I'd go with option 4: get different wheels and tires. Trying to cram +28F in without rubbing will just ruin your handling, and I'm sure someone out there will be crazy enough to buy them.
Old 09-28-2011 | 03:21 PM
niahuynh's Avatar
Those wheels are not made for S2000.
Old 09-28-2011 | 04:41 PM
RedCelica's Avatar
Buy diff. wheels with a higher offset.
Old 09-28-2011 | 06:33 PM
SDgoods's Avatar
if im fitting 9.5 +38 and 28 on a 245 i should have no problem doing a 17x9.0 +35 on a 255/40 right? Thats what im lookin at changing to
Old 09-28-2011 | 07:04 PM
you'd probably do better with 17x8 +45F and 17x9 +48R with 225/255.
Old 09-28-2011 | 07:15 PM
SDgoods's Avatar
in terms of handling? I like the meaty non staggered look but im open to anything. Truth be told i love my xd9s although they are a little agressive for my taste, id really keep them if it wasnt so bad on the tires/wheel bearings/ messing up my carbon fenders.
Old 09-28-2011 | 08:16 PM
yes, that's purely from a handling standpoint.
Old 09-29-2011 | 04:14 AM
clarkster009's Avatar
With the 30mm fenders, 17x9 +35 would be fine but would be slightly hard to fit without rubbing in rear. Remember offset is what causes rubbing and 35 is low for stock quarters. A 17x10 +45 with a 255 is an easier fit than a 17x9 +35 and would be "flush".
Old 09-29-2011 | 08:51 AM
SeanSerino's Avatar
A 17x10 +45 would stick out 3mm further than a 17x9 +35, so it would actually be harder to fit.
Quick Reply: staggered offset/Rubbing
