SSR SP1
Old 01-19-2010 | 04:43 PM
shoes59's Avatar
Originally Posted by VaderS2k,Jan 19 2010, 03:53 PM
Same sizes. Lowered 1.5in. no roll, no flare. Rubs in the front only when doing a hard turn and hitting a bump.
UK alignment specs
225/40/18
265/35/18
Thanks for the pics. On the SSR offset chart they list 34mm, 46mm, 59mm & 72mm lip sizes, with the corrsponding offsets for each size listed below. I think it's important for me to know what lip size to use in order to clear the brakes without spacers. Do you happen to know what lip size you have?
I'm looking to order the following:
17x8, 49mm offset, 46 mm lip (or should I opt for the 34mm lip)?
17x9.5, 55mm offset, 59mm lip (or should I opt for the 46mm lip)?
Thanks in advance. I just want to be sure I get the right sizes as there is no tuning back once ordered.
Old 01-20-2010 | 08:41 AM
VaderS2k's Avatar
Originally Posted by smapzy,Jan 19 2010, 08:12 PM
Vader: What's kinda offset do you have on your SP1?
Same as what he asked about. Mine are also 18's so I don't know if that changes anything really.
Edit: Went and checked the lip sizes and the other marking on the sticker is type-d for the front and type-e for the rear. Not really sure what that means because their size list doesn't have anything like that.
I measured the lips though and from what I could tell is the rear was around 72mm and the front was 46mm or so.
Old 01-20-2010 | 01:27 PM
shoes59's Avatar
Thanks. If you still have the invoice does it state anything like SL, NR, MD or HP.
According to the SSR chart there isn't a 55 mm offset with a 72mm lip. Hmmm
rikhemi
06-08-2014 04:57 AM
johnnel
03-11-2009 06:15 PM
s2kfrog
02-05-2009 08:58 AM
Abe00s2
08-09-2007 12:01 PM
SilverBullet00
08-25-2002 07:31 PM
Quick Reply: SSR SP1
