SSR rims on ebay, offset ok?
All,
I need to help with offsets. I have a 2007 S2k and love the SSR SP1/Work S1 rims. I found these on ebay but need to help to know if these will fit my vehicle. My car is unmodified, completely stock:
http://cgi.ebay.com/ebaymotors/SSR-wheel-S...1QQcmdZViewItem
4 SSR SP1, color (SBC). The front wheels are 17x8 +37offset, the rear wheels are 17x9 +37offset.
Please let me know.
Thanks,
Christopher
Please let me know.
Thanks,
Christopher
AP2,
I'm still learning about offsets, I know the stock offsets are +55 front, +65 rear but almost no one makes this stagger exactly. Can you recommend how far I can deviate from this safefully?
Christopher
Christopher
Without doin any mod's to get them to fit, as a general rule you can go about +48 in the front and +50 in the rear. Depending on the wheel and tire you choose, you might be able to go just a little bit less than that.
Chris, the setup you linked will work but I suggest you run 245 tires in the rear. set you car up with the european alignment and it will tuck the wheels in enough to be flush with the fender. I do suggest rolling the rear fender but it does not need to be pulled. This setup also depends on how low your car is.
