SSR Comp in 17"... there should be available fitment
I was checking out www.speedstar.co.jp and on the Type-C aka Comps. It appears that in 17" they have 17X7.5" at 48mm offset and 17X8.5" at 55mm offset. These should work with the S2000... maybe Jim can hook me up with a set of these instead of the ASA.
That would be nice, except TireRack doesn't import anything special from Japan.
Plus the ones in Japan are only white and bronze, where TireRacks Comps are gunmetal with polished lip....basically SSR exclusive to TireRack only. Unless SSR decides to make the current TireRack Comps in same 17" specs as JDMs, you won't be able it get it from TireRack.
