Square set up with 245/245 - using 4 Rear AP2 wheels
Old 06-07-2013 | 06:40 PM
CoolGuy094's Avatar
Great choice. I ran the AP2V1 rear square setup with 255 RS-3's for two years, autox and on the street. It was an excellent setup for the summer months, but left a bit to be desired on the colder/wetter days. I would bet your staggered set of Star Specs would outrun your non-staggered RS-3's on a wet or cold day.
Now my square AP2V1 setup has Hoosiers mounted on them... talk about a blast!
Old 06-07-2013 | 07:05 PM
SlowTeg's Avatar
CoolGuy, any problem with rubbing and was the car lowered? I take it you bored out the rear wheels? I'm contemplating running this setup. Thanks.
Old 06-25-2013 | 07:48 PM
CoolGuy094's Avatar
Whoops, sorry for the late response. Yes, I had two of the wheels bored out to fit the front (didn't use spacers). I've been on so many suspension setups I can't keep track of them all anymore... but basically when I was lowered a bit more than I really should have been and on a softer spring, then my fronts would rub the fender liner under hard cornering. That was on the Koni/Swift Spec R setup. When I was on Buddy Club N+ I was about the same ride height but no rubbing due to the stiffer springs and higher damping. Definitely no rubbing when at stock height, and no rubbing currently on my HKS setup, which is really stiff. So if you have a stiffer suspension setup then I would expect little to no rubbing when lowered.
DannyD303
06-03-2015 08:34 AM
SpaYellowS2k
02-24-2009 08:35 AM
S2k-Takara
11-16-2008 05:32 PM
s2krey
12-22-2007 08:00 AM
efthimios
12-22-2003 07:19 AM
Quick Reply: Square set up with 245/245 - using 4 Rear AP2 wheels
