Spoon SW388 w/ KG/MM DR21 Race Springs
Old 12-02-2002 | 10:12 PM
S2Thizzle's Avatar
Default Spoon SW388 w/ KG/MM DR21 Race Springs
Anybody here running the 16-inch Spoon SW388 rims with KG/MM DR21 race springs? I've read a few posts where people suggested NOT lowering the S2000 with Spoon SW388 rims. Any information on this setup is appreciated.
Old 12-03-2002 | 12:21 PM
stockae92's Avatar
i read something about "not to lower too much"
btw, what size of tires are you running with spoon wheels?
Old 12-03-2002 | 01:30 PM
S2Thizzle's Avatar
Yeah, I've been talking to turbo_pwr about the setup, and he said anything over a 1-inch drop will create rubbing issues with the Spoon rims (when tracking). The tire sizes are: front - 205/55/16 and rear - 225/50/16.
Old 12-04-2002 | 01:16 AM
stockae92's Avatar
are you running stock S02?
if i run tires other than stock S02 at the back @ 225/50,
will i get a smaller contact patch?
(i know a lot of people, even with the stock rims, runs 245/45 rear tires other than stock S02. i have 245/45 on my regamasters)
Old 12-04-2002 | 11:18 AM
Prolene's Avatar
[QUOTE]Originally posted by stockae92
[B]if i run tires other than stock S02 at the back @ 225/50,
Old 12-04-2002 | 02:23 PM
S2Thizzle's Avatar
[B]are you running stock S02?
Old 12-05-2002 | 02:29 PM
stockae92's Avatar
thanks AL, that's good reading
S2Thizzle, what kind of tire pressure are you running?
i am trying to determine what kind of tire pressure for 215/50 & 245/45?
(i assume i should run higher than 32psi for sure, i am currently testing it @33.5 psi front and 32.5 psi rear because of the low in thread at the rear)
SDUECE
04-27-2005 12:06 PM
euroS2K
10-11-2003 08:42 AM
dp2580
08-22-2003 07:55 AM
mickfluff
03-02-2003 11:55 AM
s2kpdx01
31
08-05-2002 03:31 PM
