spoon overfender, what size rims?
Old 12-27-2008 | 01:39 AM
kakahoya's Avatar
Default spoon overfender, what size rims?
planning to get spoon front and rear overfenders.
does anybody know what size is the prefered rim size?
I am planning to get Volk CE 17x8 in the front and 17x9 in the rear if possible.
Thanks in advance!
Old 12-27-2008 | 01:42 AM
dat boi's Avatar
Do you know how wide they are? 25mm? 10mm?
Old 12-27-2008 | 01:50 AM
kakahoya's Avatar
rear is 15mm wider on the top, and 18 mm wider on the bottom
http://www.bulletproofautomotive.com/catal...ail.php?ID=5561
front is 25 mm wider
http://www.bulletproofautomotive.com/catal...ail.php?ID=5560
Old 12-27-2008 | 02:41 AM
dat boi's Avatar
17x9 +45s will sit flush on oem rear fenders without "excessive" camber, so I would guess 17x9 +27 or somewhere around that offset for the rears. You will be able to run that in the front and run non stagger tires as well.
Old 12-28-2008 | 02:24 AM
kakahoya's Avatar
is that about 350z wheel spec??
Old 12-28-2008 | 11:23 AM
dat boi's Avatar
I'm not too sure, but I doubt it's far from it.
Old 02-27-2009 | 03:20 PM
Milc's Avatar
would a 17x8.5 with a +30 offset work with the spoon rear fenders?
Old 10-16-2010 | 02:11 PM
Dollabill's Avatar
Sorry to revive an old thread, but does anyone have any input on some 17x9.5 +63's all round with spoon front and rears?!
Old 10-16-2010 | 07:55 PM
VolkMan's Avatar
i'll give you the best answer possible, as I recently installed some rear over fenders(cut/weld panel)..
For the best fitment and clearance, you have to consider the following: How much camber do you want to run? ride height? tire brand/size?
Old 10-16-2010 | 08:30 PM
s2k_racer951's Avatar
Im looking to buy some rims and I found these, do you guys think i can fit these on a js racing fenders with the rear overfenders.
Work Meister S1's 5x114.3 (2) 17X10 -52, (2) 17X9 -69
