Spacers!
Spacers!
whats up S2ki, ive been here for a while but never really posted anything other than my intro.
I just purchased some 15mm option selects spacers and was wondering if the studs that come with the spacers go pressed onto the spacer itself or do i have to press them into the hub??,
Thanks for the help in advance!
The discription showed the studs pressed into the spacers, but im a bit confused as some people have pressed them into the hub and others into the spacers.
Thanks for being kind haha
yes, the studs are pressed or threaded into the spacer. Then you put the spacer onto your hub and use the supplied nuts to tighten and torque the spacer to your hub and original studs. So when you are putting your wheel on you are actually mounting it to the spacer and the new studs.
t-o_double_d
01-07-2015 12:45 PM
