Spacer question
Old 11-01-2007 | 02:00 PM
SojuSoulja's Avatar
Default Spacer question
If i'm running 5mm spacers in the rear do I need to use longer studs or can I just use the existing ones?
I'm under the impression that 5mm is ok.
Thanks
Old 11-01-2007 | 02:19 PM
Jim@tirerack's Avatar
Former Sponsor
You would need longer lugs.
Old 11-02-2007 | 04:48 PM
smoovep's Avatar
If you go this route, make sure you torque your lug nuts at least once a month, I had spacers with longer than stock studs the studs broke on me (nearly lost wheels in the process), I wouldn't ever recommend using spacers after this....
ATNCHN
10-06-2015 09:26 AM
bayareas2k
05-06-2010 09:13 AM
fishs2000
02-18-2010 05:24 PM
600rr_rocket
09-24-2008 06:37 PM
astig2k
04-19-2008 03:42 PM
