so3 tires
wow..313 days and you don't know what the last digit is on tire dimensions?? I'm not being mean....really....but that's bad!
you haven't gotten answer yet so.....
NO!!
tirerack.com is right
***pretty sure also that you can go 245's on the rear for SO3's
NO!!
225/50z15
225 = width of tread in millimeters.
50 = "aspect ratio" ......... ie, the ratio between the sidewall height and tread width in terms of % -- in this case, the sidewall height is 50% of the tire width measurement.
Z = speed rating. This is the max extended operating speed for the tire. Each speed rating (and there are several), has a specific max speed.
R = radial tire construction.
15 = diameter of the hole in the middle of tire in inches.
Rims specs are in terms of "bolt pattern", diameter, width, offset.
Each car can only utilize very specific rims and each rim can only wear a certain range of tire sizes and your tire size must be chosen on the basis of speedometer error, handling performance, wear, etc.
Originally Posted by ccluong,Aug 14 2005, 08:01 AM
just wonding if any know 225/50z15 rear will fit the stock 16 inch rims, tirerack indicates 225/50z16?
I use the S-03s and have been buying 245/45/16 for the rear. Supposedly the 245/45/16 is supposed to be closer to the original S-02s that came on the car. I've never driven them back to back on the same day so it's kind of hard to say.
Former Sponsor
I would recommend the 245/45R16 in the S03 for the rear and the 205/55R16 for the front. These will keep you closer to the OE tire dimensions front and rear.
If I can help let me know.
