Which size tires should I run?
I would recommend you go with the 255 rears with the 225 fronts. If you stay with the 245 rears you will have have too much oversteer which is dangerous in the S.
If you want to go even wider to 265 rears and 225 front, that would be fine because then you would have a slight understeer which is fine and much safer.
As for the Aspect ratio for both 255 and 265 it's 40 series for a 17" rim
9KFever: I also looked into these wheels a while back... the guys up in tire discounters said they are 100% sure they will work without rubbing... i was ok.. they said they would take them back if they didnt work!!! In the end i didnt get them decided to stay stock for now!
jay
jay
Jay, is that a photoshop of the wheel on top of a stocker? If not, is that some strange kind of hubcap? It looks like someones jacket got caught in it...
(nevermind, I get it... You put the wheel up on the jacket/towel so it'd be level with the stocker, and you took the picture to see what it'd look like.... Cool)
droptopf22
08-31-2011 07:02 AM
