size/offset gurus
size/offset gurus
please dont flame me, ive been searching and i didnt really find anything that answered my question, im a noob
will these fit?
17x7 +29
17x8 +35
i figured they'd be close if anything, but i just wanted to make sure before i got them. thanks in advance!
will these fit?
17x7 +29
17x8 +35
Originally Posted by TrojanHorse,Jun 3 2008, 02:13 PM
Is it just me or does NOBODY read the stickies anymore?
Originally Posted by ton,Jun 3 2008, 02:39 PM
as i said, i searched, but didnt find anything that helped me. so excuse me...
https://www.s2ki.com/forums/index.php?showtopic=342793
from that link
4. What fits?
Many people have tried many different wheels and tires on the S2000. Along the way, a lot of people have had problems with rubbing. Some had a little rubbing, and some had none. With all of this experimentation, a few things were figured out. The information below is not the drop dead final word of what will and will not fit. Certain things can be done to make something fit that otherwise wouldn't, such as increasing negative camber, running narrow tires, and rolling fenders, but that adds a lot of variability to this equation and thus is difficult to predict. We'll assume the owner has had a proper alignment, uses tires recommended for the chosen wheel width, and hasn't modified their fenders.
Based on successes and failures from many S2000 owners, we can use an offset calculator to figure out what other offsets and tires will work. These are minimum recommended offsets. You can use a higher offset if you want, and you will get additional fender clearance.
For the front:
205 tires: +43 offset minimum (6.5
