Should I buy another tire
I just wanted to ask if I should buy another stock rear tire to replace my left wheel. I unfortunalely hit a curb and needed to get a new right tire and rim. Will there be a difference if I do put a new tire. When I drove the car after fixing, it felt different maybe cause of the two uneven weared tires.
Just want to know basically what a new and old tire on the rear will have on handling, etc. if it does at all.
^ agreed
Also, the new tires takes a bit to break in. And before that, it has a slightly different shape (from other side worn-in surf face pattern/shape) than existing tire. The handling may be slightly off until fully broken in.
Adding on to what I said earlier, I have never had the heart to shave down a new tire, so I normally just buy new tires in pairs (and been lucky enough to mostly wear out pairs at a time).
