Rubbing up front, need details
So, I love how the new wheel/tire setup looks, love the new grip of the tires. However I also hate how heavy the setup feels (can't fix that), and I also hate how it rubs up front. I raised up the car a bit to help with the rubbing. Now it's fine most of the time, but will still rub a bit over large bumps and when I take very hard corners. Ideally what I'd like to do is fix the rubbing up front and lower the car back down a tad.
For reference, here is the back: 18x9.5 +62 with 255 width tire:
And here is the front: 18x8 +43 with 225 width tire:
My options for the front are more camber, trim the fender liner, roll the fender (?). How much of this can I get from camber alone? Keep in mind, performance is a top priority for me. I want awesome handling without sacrificing a ton of tire wear. I have no idea what the current camber settings are, but my guess is that it's pretty close to stock. How far can I go without messing up handling or killing the (very expensive) tires?
If I needed just a bit more clearance, what would trimming the fender liner involve?
Go neg 2.1 in the front. Your tires will be fine as long as you 0 the toe.
when going more aggresive on wheels and biggertire, rolling fenders is the first thing you should do, stiffen up your coilovers so they dont flex as much, and the person who rolls ur fenders will take care of the fender liner, dont go any more then 2.5 degrees of camber in the front
This project has been put on the back burner... my life is a tornado right now and fooling around with the car just isn't a top priority. Maybe this fall
