Rubbing Question
Rubbing Question
Hey wassup...I was wondering if I would rub with this set-up...I'm running Espelir ASD springs on my car which has a 1.3 drop. work meister s1's...18x8 in the front with +56 offset and 18x9.5 in the rear with +62 offset. I was thinking about getting Toyo Proxes T1R tires with these size tires...225/40/18 in the front and 255/35/18 in the rear. Will I rub in the front or rear at all?? would i need to roll my fenders at all?? Thank you in advance.
-Dex
-Dex
I have the Espilir ASD and the same tire size....less favorable offsets with the OZ superleggera wheel. I rubbed in front and had to relocate my front fender liner and roll the fenderliner mount points. Your set up has much better offsets....I think you should be fine.
On my car right now is 18x8 +55 with a 225 and a 18x9 + 60 with a 255. I have King Springs for a drop of about 1.4 inches. No problems so far but i haven't reall pushed it yet. I just got my alignment on Friday.
