rubbing on the passenger rear tire
i am running axis halos rims with 255-35-18 and when i go into a dip in the road my passenger side wheel rubs on my fender doesnt happen to my drivers side. any idea what might be causing this. how can i test the shock to see if maybe its traveling to far?
Thank you
Thank you
Site Moderator
What is the offet on the wheels? Are on on OEM suspension? When was your last alignment? There is numerous factors that could be causing it to rub. I would be surprised if suspension travel was the cause considering you are sitting int he drivers seat it should rub ont hat side due to the extra weight. My guess is something with the alignment is different. The passengers side may have less camber or more toe cause it to rub.
