Rubbing issues
Rubbing issues
Hey guys I picked up a set of Volk ce28's on here in May and Im running 18x8 in the front with a 48et with a 225 tire.. In the rear in 18x9 with a 50et with a 245 tire.. The front doesnt rub, but the rear is a tad crazy, i was slammed on ap2v1's when i got the car and when i put the volks on they rubbed in the rear so i raised it a bit, i recently got the rear fenders rolled and the rear bumper shaved at Fizz Autosports in Deer Park, LI and I slammed the back, it rubs quite often and its annoying... What needs to be done here, im not running that aggresve of an offset... Does anyone have a setup that is close to this and is having or had the same problem, I just dont know what else to do to make these work beside setting them up with some negative camber, (which im not looking foward to).. Any input is greatly appreciated!
-Shane
-Shane
When they rolled the fenders did they relocate the bumper tab? 9 +50 isnt super aggressive, and should be fine with -2 camber. If it is as bad as you say, and the tab is out of the way. Jack the car up, take off the rear strut, and lift the wheel and tire up into the fenderwell to check to see where it rubs.
This is the bumper tab, you can see how much it sticks out compared to the rolled fender:
This is a hack job, but you can see the tab has cut off, the bolt relocated further back, and the quarter panel has been trimmed almost even with the rolled fender.
Yes, an alignment is all you need to adjust negative camber. I would recomend UK spec camber, -1 front and -2 rear. Also, in the future a 245/35 is the proper diameter and would give you more clearance.
Ok well Ill go snap the car out of storage tomorrow, and ill do the whole masking tape thing to see where its rubbing, and then ill either address the issue or continue back here to you guy for excess help!
