Rubbing with 18x8
Old 11-20-2005 | 11:30 PM
Balboa's Avatar
Default Rubbing with 18x8
Wheels were free - traded for stockers. HP Racing Lightnings, 18x8 with 225/40/18 tires. Not sure of offset.
Decent bumps mid-corner the fronts rub (not sure where). Wondering if rolling the fenders should cure or if further analysis is needed.
Old 11-21-2005 | 04:56 AM
Ubetit's Avatar
It might help but knowing the offsets would tell you if it's even worth it.
Old 11-23-2005 | 06:15 AM
04RioS2k's Avatar
I'm pretty sure those offsets are around 38+ which is wayyyyyy too low for the s2k rubbing like crazy I bet......
Old 11-23-2005 | 06:46 AM
Wildncrazy's Avatar
Fronts or rears?
& yes, the offset is everything.
There is a reason the wheels were free and he wanted your stock rims!!!!
Old 11-24-2005 | 09:50 PM
Balboa's Avatar
Wish I knew the offset... Surprisingly it doesn't rub at all normal driving - just when taking a corner hard (near limit) or a mid to large bump mid-corner.
What is the optimal offset for 8" wheels?
I may end up having the wheels refinished and buying something different...
Old 11-24-2005 | 09:52 PM
Balboa's Avatar
Old 11-24-2005 | 10:00 PM
Balboa's Avatar
04RioS2K,
*** The offset is +38
Old 11-24-2005 | 10:47 PM
MugenAP2's Avatar
whoa the offset of those wheels are not at all good for the s2000. I would recommend you to run with a more ideal offset for the s2000. And on another note next set of wheels run a staggard fitment. Would look good if it was the right fitment.
Old 11-25-2005 | 10:51 AM
spa-zz's Avatar
Jeep!
Old 11-25-2005 | 12:54 PM
Balboa's Avatar
Originally Posted by spa-zz,Nov 25 2005, 11:51 AM
Jeep!
Yeah yeah, stock suspension is nice
Quick Reply: Rubbing with 18x8
