Rpf1 fitment?
Rpf1 fitment?
Okay so i've been looking into getting some rpf1's 17x7 up front with 45 offset and 17x9 in the rear with 45 offset as well. Did anyone have to roll their fenders to fit these? I am still on stock suspension btw! I am wondering because tirerack says the offset on these rims are aggressive and fender modification may be required. If anyone has answers please help. Thanks!
would my setup work with stock suspension and ride height or would i still need a fender roll?
I'm unsure. There is a wheel fitment guide in the wheel and tire section and a lot of helpful threads around this forum that can help you find that out. I'd start digging around a bit. I'm sure you'll find what you're looking for.
Here is a calculation site http://www.e90post.com/forums/showthread.php?t=153376
In the "Quest for flushness using AP2V1" wheel thread, it is often mentioned that 17mm spacers in the rear would be about the most you can go before a slight roll (depending on ride height); and it is mentioned you can easily use larger than a 10mm spacer for the front.
So, you'll want to do a slight roll on the rear fenders to be safe when going over bumps/etc for the rear, and the fronts will be just fine.
