RPF1 with 255 in front
i just recently got a set of rpf1s 17x9 45mm all around, and am currently running the stock 245s on the front (until they go bad) and new 255 star specs in the rear, i am quite low and front and rear fenders are rolled etc but i had to raise the car a little for the fronts to be okay and they are fine now but i really dont think that 255s will fit in front without major fender flairing in the front if i end up putting those tires in front too which leads to my quesiton...
Should i forget the hassle and when the time comes get 235's in the front, or does anyone know if the sebion fenders (+10mm) will be able to fit the 255s with a major drop, the only reason i hesitate from flaring the front a lot is that im just not much for the look but i guess thats also a possibility too
Let me know your opinion...thanks ahead of time
I would not try the 255/40R17 unless you are planning on pulling the fenders out. I really don't think you would need the 255 on the front anyway. I would think they would cause the car to tramline.
i was just hoping to go for a square setup and the handling already from 245s in the front is great and my fronts are slightly pulled im just looking for opinions
beefystud
05-15-2017 10:56 AM
velocityracer
01-29-2007 10:35 PM
