RPF1 17x9+45 Fitment
just purchased these victory blue rpf1's 17x9+45
have an ap2 s2000 on swift spec r springs
what tires can I fit without rubbing with a roll and tab relocation?
can I fit 255's square?
I have almost the same setup.
I'm running Koni Yellow shocks with Swift Spec-R springs with 17X9 square. I have 255s in the rear and 225s in the front.
I have -3.8 camber in the rear and -2 in the front. Front and rear required a roll as well as a tab relocation in the rear.
I highly doubt you will be able to run that setup without a roll and tab relocation. Mine rubbed like crazy without fender work.
You do not need -3.8 camber for this setup especially in the rear. Front may need -2.5 to -3 but rear should be fine with -2 to -2.5. Something else is off if the fenders are rolled and tabs relocated and you are "rubbing like crazy". You really don't need to pull the fronts much if at all but that depends on the alignment. One option is you can run 245/40/17's all around and see what you are dealing with and if you can get away with more tire.
I don't think you'll be able to run 245s in the front without rolling your fenders though. Even my 225s were giving me issues before I rollled them.
EDIT: I misread op. I thought he was trying not to do a roll/relocation.
here is a visual along with measurements of what your wanting to move to from stock ap2. Its aggressive for the front. http://www.willtheyfit.com/index.php?width=215&aspect=45&diameter=17&wheelwid th=7&offset=55&width2=255&aspect2=40&wheel_size=17 &wheel_width=9&offset2=45
And here is a visual on my 10" wheel wheel compared to yours. notice the added clearance I get with the tire on the wider rim, yet still had to pull that 10-12mm. http://www.willtheyfit.com/index.php...h=9&offset2=45
