rpf1 17x7.5 front 17x9 rear
rpf1 17x7.5 tires 205/50-17 front...17x9 tires 225/45-17 rear do i need to roll my finders with this set up my 2001 s2000 is lowered with 1` pro kit eibach springs.i really dont wanna roll my finders i f i have to go 17x7 front and 17x8 rear i with same tires just to get away with rolling finders i will....
205/50-17 and 225/45-17 tires are both taller than stock AP2 sizes, might not be any less likely to rub than AP2 sizes: 215/45-17, 245/40-17.
Did you pick those sizes based on the Tire Rack website?
why are you running such oddly sized tires on those wheels?
the recommended tire size for that wheel sizing is: 215/45/17 front and 245/40/17 rear, or even 255/40/17 rear
if you wanna be safe just run the 245/40 rear and you should be fine without rubbing with a little camber
I have these in 17x8 and 17x9. I definitely recommend either 215/45 and 245/40 or 225/45 and 255/40. With only being lowered an inch you probbaly won't have to do much if any rolling of the fenders.
im on 17x7.5 48et front and 17x9 45 rear lowered on espiler's and had to roll the rears but not the front! ohh yea and im on stock ap2 tire sizes
estewkay_frankenstein
06-03-2013 10:28 PM
