rota slip stream fitment +48 offset
Hi folks,
planning to buy rota slipstreams 17 x 8j front +48, 17 8.5 j rear +48.
tyres to be fitted are 215/45/17 F and 245/40/17R.
my suspension is fully stock, with camber of -1.5 F and -2.5R.
according to the wheel fitment guide this size is safe but says i may need a roll/tab replacement
Anyone know if i definitely need an fender roll or tab repositioning? My hope is i do not need to touch the fenders.
Originally Posted by s2k dre,Aug 31 2009, 10:30 PM
The fronts will be good, the rears u should clear, ur only 17mm more than stock fitment but u got to mount thr wheels and see.
Originally Posted by c32b,Sep 1 2009, 02:57 AM
i'm really hoping to know before i order the rims. dont wanna spend unncessary cash to get a rim that dont fit right... a bit worried that the rears will rub?
I have those exact rims in those exact dimensions, on my stock ride height S. Even on very bumpy roads (note I am in Greece ), I've had no problems whatsoever, you do not need to touch the fenders or use spacers, or even change the camber.
Corey Maurer
05-14-2010 09:48 PM
