Rota D2 Question !
Rota D2 Question !
Could u tell me if this is a perfect fit on an ap1 stock suspension
ROTA WHEELS - D2
Size
17X8.5"
Bolt Pattern
5X114.3 mm
Offset
50 mm
Lip Size:
1.5"
Hub Bore Size:
73 mm
ROTA WHEELS - D2
Size
17X8.5"
Bolt Pattern
5X114.3 mm
Offset
50 mm
Lip Size:
1.5"
Hub Bore Size:
73 mm
and also can someone have those on picture because im not sure if i should get 17inch or 18inch :S
any big difference between 17 or 18 inch ?
and what tire size would you put on 17 inch ?
depends what you want to run. 18 is bigger obviously. same goes for the tires, you can run whatever you want depending on how much of a stretch you want. im running 235/40/17 on my x8.5, which is a bit meaty, people have also ran 225/45/17 and so on.
someones selling a set in socal if your close by for 400 or ask to ship them.
https://www.s2ki.com/forums/index.ph...pic=828488&hl=
I heard from a few people that the 17" D2's wont clear our brakes. That is why everyone runs 18". Could just be a rumor. I have never had them, just sharing what I have heard before.
