rookie questions...
rookie questions...
what effect, if any, does changing the tire diameter have on performance?
does this put increased wear on the transmission or other systems?
does it throw off the speedometer/odometer?
If you get a wheel and tire that is as light or lighter than stock ther would not be any negatives other than a little stiffer ride. The speedometer and odometer and gear ratio will all be the same if the correct size tires are used.
If I can help let me know.
Thank you
Jim 800-428-8355-364
Thank you
ayelien
06-10-2004 07:41 PM
all-trick'd-out
03-25-2004 02:23 PM
