Rim size? PLEASE HELP
i need some help before i buy those rims please.... i have 19x7.5 all around ARD and wanted to change the size to 18' (my friends think that 19' are too big for s2k) anyways i was wondering if the size on these rims is ok for the s2k
thanx ed
Wheels size
Front (2)18x8.5 (2.0" polished lip)
Rear (2)18x9.5 (2.5" polished lip)
Bolt Pattern 5x114.3
Offset +35mm
thanx ed
Wheels size
Offset +35mm
+45 is better, but ideally you'd want to be in the +50to55 range for the front and +60to65 for the rear, imo. I'd recommend getting 225/40 up front just to avoid some of the rubbing. And 255/35 for the rear, again, just to avoid some rubbing because it'll still be there if you're lower than 1.25".
