RFP1 w/ +35 offset will they rub ?
Hello,
I'm looking to buy the 17x8 +45 offset front and 17x9 +35 offset rear. Plan on using stock tire sizes 215/45 and 245/40.
My question is will the rear tires rub ? Should I be going with the +45 offset?
thanks
thanks
Is there something I can do to stop the rub? Or should I just get the +45 offset.
Also the website I'm buying them from list as +35 offset...here is the link....
http://www.1010tires.com/wheel.asp?wheelbr...l=RPF1+%2D+Gold
I think you will still rub if you run 45 offset in the rear, if you don't roll your fenders.
A buddy of mine ran 17x8/17x9 setup, 45 offset on stock AP2. 215/45/17 & 255/40/17 and he rubbed around corners. 245's might make a slight difference (0.39") vs 255's.
Thanks Everyone, your advice is much appreciated,
Anyone know why the Tire Rack RFP1 selection is limited to silver and black only and limited sizes.
1010tires.com has way more selection...
