replacing s02 rears w/s03?
I need to replace the rears but, from what I have heard, the s02s have been discontinued. I have read that rear s03s should be ordered in a different size, but can they be matched with oem s02s in front? I would prefer not to replace all four tires when two are still in fine condition. Or, preferably, does anyone know where I can buy two OEM s02 rear tires? Thanks...
You can easily get rear SO2s off of the tirerack.com.
Go to: http://www.tirerack.com and select as MAKE, 2002 Honda S2000. When it brings up the OEM tire sizes, select view best sellers, and it will bring you to a page from which you can purchase them. I just did it the other day, so I hope this helps.
Former Sponsor
ETBrondo is correct, the OE tire is not discontinued. They did discontinue the S02 Pole Position. The car will handle better with matched tires front and rear.
If I can help let me know.
Thank you
Jim 877-522-8473-364
Thank you
