Replace S-02 with RE-01R -
Old 12-12-2007, 05:44 PM
iDomN8U's Avatar
Default Replace S-02 with RE-01R -
225 OEM S-02 replacement tires normally require a 245 tire, but is the RE-01R eqivalent? Has anyone checked the contact patch?
Old 12-12-2007, 07:08 PM
sunrise089's Avatar
It isn't the exact same, but many feel the 01R is such a good tire a 225/50/r16 is an OK option.
Old 12-13-2007, 02:53 AM
Rprsntng757's Avatar
I have 225/50r16
amazing.
Old 12-13-2007, 04:58 AM
iDomN8U's Avatar
It would be intresting if someone could measure out the dimensions for each.
Jim?
Old 12-13-2007, 05:11 AM
ZDan's Avatar
You cannot characterize tire performance based strictly on dimensions. There are factors that are far more important for tire performance.
245 is not a "requirement", 225's are just fine. It is more important to ensure that the appropriate tire for usage is chosen.
Old 12-13-2007, 06:00 AM
Ubetit's Avatar
Section width on both is 9.2"
tread on S02 is 8.5"
tread on re-o1r is 8.3"
They are pretty close but the compound of the Re is supposed to be better.
Old 12-13-2007, 07:01 AM
Elistan's Avatar
I don't think a 245 width RE-01R is made in 16" size.
Tire Rack only lists:
205/45ZR16
205/55VR16
225/50VR16
Old 12-13-2007, 09:13 AM
iDomN8U's Avatar
205/45ZR16
205/55VR16
225/50VR16
Exactly...
As this has been discussed thoroughly, yet there are few choices to find a direct replcement for the S-02 OEM
I have tried the Toyo T1-R 245-50-16 and was not happy and returned them.
In my search for a replacement the 225-50-16 replacements were out of spec due to the fact they would have a taller side wall and smaller contact patch compared to the OEM. If this wasn't a factor I would have purchsed the Goodyear F1's
In either case, some manufacturers are different then others in terms of size comparisons general example: Hankook's Z212 225-50-16 had slightly different dimensions then lets say Toyo's T1-R 225-50-16
Is there a significant physical different (not rated #'s) between the S-02 225 and the RE-01R 225? The true test is take tape to each of them.
Old 12-13-2007, 11:24 AM
ZDan's Avatar
Again: There is a *lot* more to tire performance characteristics than what can be measured with a tape measure.
The first thing to as yourself is: What do you want/need from your tires?
Max dry grip? RE01R
Driving rain/standing water/wet traction a concern? RE050A Pole Position
Price a concern? Hankook RS2 (these did an awesome job for me on the street and at the track, btw)
Life more important to you than outright grip? Bridgestone RE750
Cold weather/snow usage? Bridgestone RE960AS Pole Position
Dedicated Winter tires? Dunlop WinterSport M3/3D (I just drove 33 miles of backroads through the snow in SE Mass/RI on these, no problemo!)
There are other options in each of the above categories, those are just what I'd pick.
Old 12-13-2007, 12:15 PM
iDomN8U's Avatar
According to a Tire Size calculator, it's a 3.1% variance
Is that acceptable? ie: ABS/speedometer?
Quick Reply: Replace S-02 with RE-01R -
