Remove material from wheel hub surface?
not even sure if its possible
im just bored lookin at pictures and thinking
would it be possible to mill some material off the hub mounting surface to change the offset of the wheel
like i want to run 17x9 +35 ce28's
but that wheel from volk doesnt concave and doesnt really have a lip
what if i were to buy a 17x9 +15 and have 20mm taken off the hub surface would that make the wheel a +35 offset ? or am i retarded?
you would have a 17x9 +35 with the concave center and nice lip of a +15 wheel
thanks for any insight
Great question. I was thinking of having 5mm's shaved from the hub face on the 17x9 RPF1's I just bought. But you have to consider several factors including caliper clearances, loads etc. I suppose 3-5mm would be OK as long as you have the caliper clearance but I would'nt remove any more than that.
Keep in mind I'm not an engineer nor claim to know if this is safe but I think it's a great question for those looking to customize the look and stance of their car.
Looking forward to hearing from those in the know.
Originally Posted by CarBoN,Jan 22 2010, 05:27 PM
but removing material will bring the wheel in closer to the car? making the offset higher
to get -5 from a + 15 you would add a 20mm spacer
gotap1
03-28-2017 04:19 PM
