Rear Replacement
Rear Replacement
Just tore up my driver-side rear tire. Had a screw in it and it went flat ruining the sidewall. Wasn't driving fast (65mph) for about 8 miles and couldn't really tell that it had gone flat ... except that the S2K would pull to the left when I accelerated. Thank God we weren't out pushing it on a twisty mountain road (which I had been doing a couple of days ago).
I have 12K miles on the tires and the rear tread was at 6.5/32s -- so, about half gone.
Should I replace both rear tires or just the one that ran flat?
Also, would assume that I should put the same tire back on (OEM Potenza RE050) unless I want to upgrade all four.
Replace both rears and you can go with a higher performance in the rear if you want imho. It would give you a little more understeer if anything. Jim can give you the best answer.
ragamuffin
02-03-2006 07:23 AM
