RE-11 on AP1 wheels
Old 07-17-2012 | 10:24 PM
jbleee's Avatar
Default RE-11 on AP1 wheels
I've been searching and lurking for the past week in regards to this. Recently I put star spec Z1's on my 2002 S2K in OEM size (sizing the same as the S-02s and on the door jam of the passenger side). I do notice the rears (Star Specs) look narrower/not as square compared to the S-02s i had on before and also the fronts look a little beefier. I have RE-11s on order as well with the same OEM size for the fronts but rears @ 245/45/16. The sticky in this forum mentions that 245/45/16s were the more accurate size but that sticky is old and i dont think the RE-11s came in that size at the time.
So my question is since the RE-11s are here now in that size and perform pretty close to the Star specs, do i swap my star specs(OEM size) for the RE-11s which might be the perfect aftermarket setup for stock AP1 wheels??? Maybe the RE-11s in the 245/45/16 were made with the S2K in mind?
Thanks!
Old 07-18-2012 | 07:24 AM
deepbluejh's Avatar
I read this probably 5 times trying to make sense of it, but had little luck.
You recently put Star Specs on your Ap1. Despite recently buying new tires, you bought RE-11s as well (why?). Now you want to know if you should swap out your new (?) Star Specs for RE-11s?
It would have been smarter just to buy the right tires the first time. That said, I'd be incline to just use what you have and not worry about the RE-11s. Both of these tires perform better than the S-02s that originally came on the car.
Old 07-18-2012 | 09:07 PM
jbleee's Avatar
the bottom line:
on AP1 OEM wheels R:225/50-16 F:205/55-16 (Star Spec Z1)
Or
R:245/45-16 F: 205/55-16 (RE-11)
Old 07-18-2012 | 09:19 PM
Carbon Blue's Avatar
you should be fine with the star specs, many people have that setup. Thats crazy, I never knew the re11 came in a 245/45/16 size. It must be new
Old 07-19-2012 | 12:23 AM
dsthez's Avatar
they just came out
Old 07-19-2012 | 03:57 AM
ZDan's Avatar
Originally Posted by jbleee
the bottom line:
Or
OR
205/50-16 F, 245/45-16 R
OR
225/50-16 F, 245/45-16 R RE-11
Old 07-19-2012 | 06:54 AM
Jim@tirerack's Avatar
Former Sponsor
The RE-11 did just come out with the 245/45R16 size. Both the Star Spec and the RE-11 are excellent handling tires on the car. You will not be making a bad choice either way. If I had my choice the RE-11 would be the tire but the Star Spec is a lot cheaper.
If I can help let me know.
Old 07-19-2012 | 03:21 PM
Originally Posted by ZDan
Originally Posted by jbleee' timestamp='1342670856' post='21871651
the bottom line:
Or
OR
OR
damn, now im kinda wondering if I should go with a 225/50/16 in the front and the 245 in the rear with my ap1's. Im wondering if the front will look too bulgy sidewall wise since its only a 6.5inch wide wheel. Does the sidewall in that size become more flexy as well??
Since extreme performance tires run a little wider than regular max performance tires, does anyone know if the 245/45/16 re11 will actually measure out to be a 255 etc.? I should be able to maintain the stockish characteristics since the factory stagger is maintained correct? With the only difference being a wider contact patch?
Old 07-19-2012 | 03:59 PM
iDomN8U's Avatar
the S0-2 225/50/16 are closer to a 245/45/16 then another brand 225/50/16
I thinking I will be doing the same thing with mine.
Old 07-20-2012 | 08:54 AM
ZDan's Avatar
225/50-16 does look more bulgy on the stock front wheels than 245/45-16 looks on the backs. Also, this combination has the rears slightly [edit] *shorter* than the fronts. The overall effect is that it makes the front tires look BIGGER than the rears.
Honestly, for a street setup, I'd probably just go with factory OEM sizes.
Lookswise, 205/50-16 fronts look better with 245/45-16 rears (slight "smaller fronts/bigger rears" look).
