R888 Experience?
Old 02-07-2014 | 09:57 AM
tua40278's Avatar
Default R888 Experience?
So I've been contemplating tires now for the last two weeks.
My car is supercharged, 400 whp. It maybe sees 3,000 miles a year (a fun spirited drive through the mountains here and there), but will be autocrossed roughly 6-10 times this year.
Last year I had the re050's, and then I supercharged it and just stuck with the re050s. They were horrible when autocrossing. I obviously need something that will provide more traction.
So I'm thinking about switching over to the R888's. I'd prefer to be lazy (if possible) and would like to not switch wheels every single time I choose to autocross. It's garaged kept, temp controlled 24/7 so the tires would never see freezing conditions.
I thought about going with some Z2's, but then I told myself I don't drive enough to worry about the tread life of the R888's so I might as well go for the R compound tire.
All I'm asking of the r888's is to last one year...3,000 miles and roughly 6-10 auto crosses while being stored on the car in a temp controlled garage. Is this too much to ask?
Old 02-07-2014 | 10:12 AM
Jet3010's Avatar
You should PM Killerblackbird. I know he had them in a 255 square setup last I saw.
Old 02-07-2014 | 11:57 AM
s2000Junky's Avatar
I have run the old RA1 on the street before, but not the newer R888. It sounds like you could justify running them with what you have laid out here. I think with the 6-10 autocrosses and 3k street miles a year, that’s about what you will get out of them. Don’t expect them to be the same great performers on the street after several autocrosses/heat cycles though. I say go for it and you will learn first hand what to expect and if you want to do again in the future. I always like to try things out for myself, you cant account for every variable.
Old 02-07-2014 | 12:25 PM
cdelena's Avatar
I used to run my track tires on the street in the summer and really liked the performance but found a couple of problems... a surprise rain makes things interesting since mine always had little or no tread, they were sticky enough that all the starts and low speed shifts that happen on the street and not the track put a little more stress on the drive train (I did crater the diff on a hard shift), and finally some people take exception to the tires... won't pass a state safety inspection, and AHM rep initially declined to cover the diff after a inspection.
05rioS2K
03-22-2015 11:11 PM
ramblin_wreck08
02-20-2013 06:37 PM
pw91686
06-07-2010 08:41 PM
heffergm
03-01-2004 02:15 PM
Saab9-3
10-01-2003 10:11 PM
