Quick fitment,suggestion question
So im interested in a set of wheels with these specs.....
front: 18x8.5 with +35 offset
rear: 18x9.5 with +40 offset.
Pretty much my question is what kind of rolling and pulling am i looking at here?
By what i have seen and searched for im going to absolutely need a roll and probably a pretty aggressive pull? or maybe i know less than i think
also was seeing that ill probably need a fair amount of camber?
Please enlighten me.
and for what its worth i will be putting a moderate stretch with the tires also
TIA
TIA
of course.....but gettin fenders pulled is not a easy task. You really need to know what your doing for that.. I'm running 17x8 +38 and 18x9 +42. with no gap
my rear rubs with a 215 and -2 camber... Its fine with a 1 inch finger gap, but if i want to go lower, i need more - camber and possible a smaller tire or else i rub when i hit bumps
hmmm i c. so you are not pulled and thats the situation you are running into?
Pullin isnt a huge issue with me, ill take it to a local shop that is known for having good abilities at fender rolling and pulling. nothing im going to try myself.
