Question re: S-02s and oversteer
Less than an month now with the S and I'm in the need of new tires as the S-02s have less than 20% tread. Anyway, making a 90 deg turn last night and I lost the back end on the throttle. No big deal, I grew up driving a rwd Volvo in the snow and straightening it out the S was easy. I was surprised at how little (no) warning the tires gave before they broke. Is this tire known for little warning? Or was is it a function of the tread wear? BTW, it was quite cool (10C) but I had been driving for about a 1/2 hour so the tires weren't stone cold. Thx.
Your SO2 have high limits of adhesion when warmed up properly, however, once that limit is reached, break away can be sudden. Also, as the tread wears, the compound further down has been subjected to its own lifetime of heat cycling and can change in its chemical make up. Many have noted that even under ideal conditions, handling characteristics change as the outer tread wears off.
Additionally, your tires need much more warming up than what our (Alberta) recent temperatures have allowed. The pavement and ambient temps are simply too cool for adequate tire warm up, even after 30 minutes of normal street driving (next time, stop and feel the rubber). In the evenings around here now, the pavement can contain high moisture content as the temps fall. This makes for much more slippery conditions and also hinder tire warm up. Now is the time that we muct all be more careful in taking those "exuberant" corners. Pretty much expect a power slide and drive in that fashion or just take it down a couple of notches.
