Question for Jim
Question for Jim
Hi Jim,
Can i run the set up 215-40-18 18x8 +49 front and 255-35-18 18x9 +62 rear ?I know 225-40-18 is the ideal for the front but i i just want to be safe, i dont want any rubbing issue. The front is 18x8 +49.Is this set up ok?Im lowered 1inch.TIA
front will probably be fine but rear with 18x8 49+ with 255-35 will probably rub so try sticking with 245 instead....also your tire selection will also determine if you rub or not....
Originally Posted by spa-zz,Mar 28 2006, 03:25 PM
Wait a sec... 255 with a +62 offset should be fine...
Former Sponsor
The 225/35R18 is not a good size to go with. It can even throw off the anti lock brakes. Just go with the 215/40R18 or the 225/40R18 front and 245/35R18 or 255/35R18 rear.
You actually should be fine with any of these size tires.
If I can help with the tires let me know.
JsAP1, people have reported several times that they rub with a 48 offset and a 225 tire on the front.
So how can we recommend it to people unless we qualify it by saying "You may rub unless you use additional camber or modify the fender."?
I'm not trying to say that you're wrong, because clearly some people have issues, and some don't. But I think rubbing is a big deal to the average guy, so I find it hard to recommend those setups to people. What's your take on this?
If he goes lower than 1.0 inch drop then he will run the chance of rubbing, again thats a chance, dependant on his road conditions and the brand of tires he uses. All tires are different regardless if they are the same size.
So for the average Joe with a 1 inch drop he can run a 225 front tire with that 18x8 +49 front and not rub. If he chooses to go lower than that, then he may/will rub. Have you seen a 215 tire on a 8 inch wide wheel? Its stretched and he has more chances of damaging/bending his wheels than rubbing.
If this were me I would go 225/35/18 OR 225/40/18 fronts and 255/35/18 rears with a 00 upto a 1 inch drop. If it were a 18x7.5 then yeah I would recommend a 215 tire but its an 8 inch wide wheel. Maybe I am wrong, I dont know..
