Question about SSR Competition wheels...
[QUOTE]Originally posted by HondaGuy
[B]
Take directly from the link above...
16x7; 42mm offset
16x8; 45mm offset
So, you think the offsets for the 16" version is good enough for the S2000?
[B]
16x7; 42mm offset
16x8; 45mm offset
They are making the 17" for us but the 16" will not be available in the correct offset. We do not show a correct size tire for the Yokohama AVS Sport in the 18". The tire sizes we recommend would be 225/40R18 front and 255/35R18 rear.
Let me know if I can help.
Thank you
Jim 800-428-8355-364
Thank you
Originally posted by JT-KGY
Where you get those numbers for 16"?
I only found 17" ones...
www.speedstar.co.jp/collection/type_c/spec.html
I'm not surprised SSR won't be making an application for the 16" wheels. Why? B/C most people that buy aftermarket wheels wants bigger then stock size wheels.
Originally posted by RT
Jim I know we've had this conversation before and I'm sure you're about sick of me by now, but the 225/40-18 on an 8" ET 48 is going to rub (I had x8 ET 52's that rubbed)
I can't wait for the SSR Comp's arriving later today for my hatch. I'll post pics here...Remember, just don't laugh too hard when you see my wheel well gap (Yeah, I know I need to lower it) .
Corret me if I'm wrong (RT? ), as long as you have the overall diameter of the tires the same as the oem tires, then it won't mess up the accuracy of the speedometer, right?
will be a few mm off... (some %)
Correct me if I'm wrong (RT? ), as long as you have the overall diameter of the tires the same as the oem tires, then it won't mess up the accuracy of the speedometer, right?
If you really want to split hairs, it's not the diameter, it's the rolling radius (takes sidewall deflection into account). The tire companies used to publish this number more commonly but it seems now a days the "IN" way to express this dimension is by stating Revolutions Per Mile (I believe the stock SO-2's are 837 rev/mile).
If you stay within a % or so of this on the rears (say 825 to 845), I don't think you'll notice the gearing (or speedo) difference.
