Question about fitment
I finally found some wheels that I like. These are the specs available on this wheel, but again, i have no idea what would be the ideal size for the front and rear tires or wheels. My guess is 8 1/2 for the front and 9 1/2 for the rear, but then again, what tires should i use?
I'm just speculating here, I dont even know if these wheels will fit without rubbing since I have tein s-tech springs on my car on stock shocks; thats like a 1" drop all around, maybe a bit more.
Need help here guys.
18"
Size Offset
8 1/2J 42
9J 18
9 1/2J 45
10J 22
18"
Size Offset
8 1/2J 42
9J 18
9 1/2J 45
10J 22
18"
Size Offset
8 1/2J 42
9J 18
9 1/2J 45
10J 22
Size Offset
8 1/2J 42
9J 18
9 1/2J 45
10J 22
A 9" rear rim needs about 65 mm offset to look right. You are 1/2" wider and 20 mm short on offset on this one.
Add in 1" lowering and the proper sized tires to fit those rims and I think you're going to start grinding off your wheel well edges with every dip in the road you hit.
CeleSaga83
03-30-2004 09:35 AM
