Question about fitment on 19 inch wheels/tires
Hey,
I have the opportunity to pick up a great set of wheels with the following stats:
19x7.5
Front: 225/40/19
Rear: 245/40/19
Offset: 42mm.
Will I experience rubbing at stock height without fender rolling? Is this a good handling combination?
Thanks for the advice!
19x7.5
Front: 225/40/19
Rear: 245/40/19
Offset: 42mm.
Way too tall of a tire. That's 2" larger in diameter of stock. I would honestly recommend 215/35-19 (front) and 245/30-19 (rear). It will keep you around stock diameter. I'm not sure if you can pinch the 245/30 on a 7.5" wheel b/c the sidewall might be a little too small. As far as handling, no it is not a good set up.
Former Sponsor
That wheel really does not give you good options for tires on the S2K. The offset is pretty low also. The best tire size would be 225/35R19 all the way around if you use that wheel.
