Prodrive gc07c source?
Old 01-12-2012 | 04:17 PM
abrahams600's Avatar
Default Prodrive gc07c source?
Found them...
Old 01-12-2012 | 08:13 PM
FISH22's Avatar
There's really no source for discontinued GC07Cs. They're extremely hard to come by, especially just one wheel. Might sound stupid, but have you thought about just throwing a 4mm spacer behind the one +48 wheel? That would make it sit even with the others.
Old 01-12-2012 | 11:37 PM
Mar48's Avatar
I don't think one should ever use a spacer on one wheel.... it won't be the same. May be dangerous.
Old 01-13-2012 | 08:47 AM
Yes, I thought about that but after looking at the lug holes it's going to affect the structure of the wheel. I can safely shave about 1-2mm.
There's nothing wrong with running 1 spacer, it wouldn't be dangerous at all. I mean, what would be the difference between 1 spacer or two. However, you can't run anything above a 3mm spacer on an s2000 because it won't catch the hub to be hubcentric and there won't be enough turns on the lug nuts to be safe if using 4mm or 5mm spacers, unless using extended lug studs.
I've found two pairs and 1 spare already. Thanks guys...
Old 01-13-2012 | 01:01 PM
FISH22's Avatar
Good stuff
Old 01-14-2012 | 08:41 AM
Mar48's Avatar
it might be minimal, but the weights on each side would be different/rotation inertia would be slightly different... That's the difference between one or two spacers. With two you will have the same weight on each side.
Old 01-14-2012 | 10:05 AM
The spacer is on the center of the wheel, that's where the rotational inertia is concentrated, a 3mm aluminum spacer weighs 5-6grams so it won't be much of a difference. The wheel with the lower offsets would have more material on the pad (i.e weigh slightly more), by adding a spacer on the wheel with the higher offset you're balancing the weights on each side. I can just weigh each wheel and calculate the weight of the one with the spacer to match the weights for both sides.
Dillon_93
06-22-2016 12:17 PM
Tacoman22
06-20-2008 07:28 AM
RHAP1CD2
02-27-2007 11:35 AM
Quivers
06-04-2006 07:25 PM
dailodailo
10-18-2003 10:41 AM
