Please Help! Is this Offset OK?
Ryan what size wheels and tires are you planning to run in the front?
Look here for a quick explanation of what offset is http://www.tirerack.com/wheels/tech/offset.htm
Also give a call to Jim at Tirerack and he should be able to help you figure out your offset problem and get you into the right set of tires. His number is 877-522-8473-364
Ryan
Bump...last question...will i be able to run 255/35/18 tires with the 18x8, 5.114.3, with a +55 offset? Please help as I am ordering the wheels Monday and the tires possibly next week as well. thanks to whoever helps!
Ryan
Ryan
