OZ Ultraleggerra
OZ Ultraleggerra
I was looking on the TireRack site for some wheels and found the Oz Ultraleggerra which I really like. The only issue is the color, I am not a fan of silver wheels as they just look too much like oem to me. I saw that this wheel is available in matte graphite in 18" sizes but it is not offered on the site. Can you tell me if this wheel is available or not? Also could you tell me how this would look on the car (will it rub, stick out past fender well, etc.) the specs it gives are as follows front:18x8 48mm offset, rear:18x9 55mm offset. I also liked the Kosei K-1 TS, it was listed as 17x7 50mm offset and 17x8 45mm offset, but I am confused as to why the offset on this wheel is lower in the rear than front . Any help is much appreciated.
The only finish available is the crystal titanium. They discontiuned the other finishes. The tires that will work would be 225/40R18 and 245/35R18 rear. You can use 255/35R18 on the rear with a little fender lip roll and or more negative camber.
