Ordering Sumitomo HRTZ III
Was just informed by Jim that they dontmake the HRTZ III for 16s!
Any suggsetions on dd tires for ap1 rims?
Hi All,
i am just wondering what is the right size for AP1 with AP1 stock rims?
is it
front: 205/55/16
rear: 245/45/16
for this tire?
what are other recommended set up as well since it seems like a lota people have these on as well.
Thanks!
Hi All,
is it
front: 205/55/16
rear: 245/45/16
for this tire?
Thanks!
Max dry grip?
Max wet/dry grip?
Track use?
Longevity a factor?
Any snow/ice/cold usage?
Price a factor?
As for sizes, stock 205/55-16 front with 225/50-16 rear sizing is fine, and this sizing will yield the greatest selection.
245/45-16 rears is a fine alternative, but there aren't as many tires available in this size. 205/55-16 fronts are a little taller than the 245/45-16s, pretty close but noticeable. You might consider 205/50-16 fronts to avoid the "big-fronts/little-rears" look. Or not... 225/50-16's fronts would be another option with 245/45 rears, but then the fronts look absolutely HUGE compared to the rears.
Originally Posted by my2ks2k' date='Jan 14 2009, 01:38 PM
ZDan will be here any minute now...
Wouldn't want to disappoint anybody...
[quote name='ZDan' date='Jan 14 2009, 04:39 PM']Best tire model for you depends on what you want/need from tires.
Max dry grip?
Max wet/dry grip?
Track use?
Longevity a factor?
Price a factor?
Max dry grip?
Max wet/dry grip?
Track use?
Longevity a factor?
Price a factor?
You probably want either Ultra High Performance summer tires or Ultra High Performance all-seasons, depending on the likelihood/avoidability of driving in winter conditions (snow/ice/cold). You do NOT want to be driving an S2000 in the snow on summer tires...
RE050A PP (Max Performance category tire) is going to give excellent wet and dry grip but at the expense of longevity.
RE960 PP (UHP all-season) is going to give some small amount of usability in the snow, at the expense of slightly less wet/dry grip on the street in warmer weather.
The Tire Rack website is your friend, the only thing they lack is they don't carry Toyo or Falken tires.
Tire Rack UHP summer tires
UHP Summer tire rankings
Tire Rack UHP all-season tires
UHP all-season tire rankings
Lots of test results for many tires models are available in the Tire Rack website as well, this will help you narrow down your choices.
ferexample:
http://www.tirerack.com/tires/tests/...ay.jsp?ttid=97
http://www.tirerack.com/tires/tests/...y.jsp?ttid=115
Root around the site for a while and see what you think is best for ya.
ferexample:
Max dry grip?
Max wet/dry grip?
Track use?
Longevity a factor?
Price a factor?
Max dry grip?
Max wet/dry grip?
Track use?
Longevity a factor?
Price a factor?
How common is it to run this size? I don't want my front tires to appear larger than my rears..
Would running this front tire size have any additional benefits/hinderances compared to a 205/55/16? Or is it strictly a looks thing?
Originally Posted by ~blacks2k~' date='Jan 15 2009, 04:39 PM
Really, so if we are running 245/45/16's in the rear we should consider 205/50/16's for the front tires??
[QUOTE]How common is it to run this size?
