one last check before ordering
I'm about to order some work D9R. Rear 18x8.5 +53. AND front 18x7.5 +47. I know I can get them to fit. I'm just curious will I have to do a tab relocate or rear over fenders. I'm running bc coilovers and seibon cf +10mm fr. Fenders. Ill be wrapping them in rear 255/35-18, front 225/40-18. Thanks for the help
Fronts should be fine with +10mm fenders. The rear might need a slight roll and tab relocate depending on your ride height and alignment settings. You aren't even close to needing rear over-fenders, no worries there.
Site Moderator
I doubt it will need a roll at all. These are very conservative wheel specs especially for having wider front fenders. They are going to look fairly sunken in.
