Ok, Who is right, Who is wrong? 18" wheel ideal tire size.
Old 03-31-2004 | 10:37 AM
RossoS2K's Avatar
Im going to go with
255/35 18s in the rear
225/40 18s in the front.
Thanks everyone for the advice.
Old 04-03-2004 | 07:57 PM
davidb's Avatar
The reason you are hearing different things about rubbing is that they are all running different brand tires.
The 255 size isn't an absolute size it is more of a suggestion. You will find as much as a 2" variance in actual width in the same size. Some of the narrower brands have even quit publishing tread width specs.
With an 8" wide rear tire (narrower than stock) I rubbed at 54 offset.
With a 10.2" wide rear tire I rubbed the same way with a 63 offset. The rubbing was only the attachment point of the the inner liner to the fender which can be modified to make your tires clear.
There are way too many variables to say one offset works or doesn't work or to say one size works and another doesn't.
What tires do you intend to run with those rims? That's the key. Find someone with the same tire and see what they have to say
Old 04-12-2004 | 10:16 AM
S2000_Europe's Avatar
According to Bridgestone For a 9" with wheel you should run 245
For a 17x8 and 17x9 which are the best?
I was thinking in:
225/45/17 Front
245/40/17 Rear
are this enough rubber for 300WHP?
thanks
Old 04-12-2004 | 01:25 PM
JT-KGY's Avatar
for 17x9, you can run 275/40's
for 17x8, you can run 245/40's
it's probably a better idea too if you're running that much hp..
Old 04-12-2004 | 01:35 PM
275 more rubber than a M3 CSL
Thanks JT
DangerZone9K
05-27-2012 07:01 AM
RedRocket13
07-22-2011 10:49 PM
oompa611
01-30-2005 09:37 PM
AndyP
04-28-2003 03:12 PM
Knowledge
07-19-2001 02:29 PM
