offset problem
offset problem
Dear all s2k owners
i'm planning to buy a set of rims for my car and the size i want is 245/40/17 all around....i will install after market suspension too so can all u pro's out there tell me wht offset will suit my car for not needing to roll fenders or any other work...?
thxs
thxs
Former Sponsor
The best thing to do is go with the highest offset you can get. I would suggest going around a 55mm offset or higher. If I can help with the tires let me know. I do have the Michelin PS2 on sale at 154.00 each.
17x9 +63 if i install these set of wheels front and back and A050 tyre would that be ok? thinking of 235/40 front and 255/40 rear...is that rim size ok to fit those tyre without rubbing?
Originally Posted by nigoape1,Sep 14 2010, 10:11 PM
sorry guys its 235/45/17 and 255/40/17 will thsi rub using 17x9 +63 and A050 tyre?
thxs very much
thxs very much
235/45's would be taller than 255/40's and would be more likely to rub.
235/40's would be shorter than 255/40s by about the same amount, better aesthetically and less likely to rub.
Former Sponsor
I don't like the 235/40 or 235/45R17 on the S2K. One tires is shorter than stock and one is taller than stock. They are also going to be taller or shorter than the rear tires.
So guys wht tyre size should i go for ...??
cos i will only do the car on track so handling will be my first issue
235/40/17 front 255/40/17 rear
245/40/17 front 245/40/17 rear
255/40/17 front 255/40/17 rear
and guys pls give me the best offset with no rubbing plz....cheers guys
