Offset-in-a-picture.
Old 03-01-2006, 06:29 PM
spa-zz's Avatar
Originally Posted by neveronlines2k,Mar 1 2006, 07:31 PM
I was running 17x7.5 +43 in the front & rear without rubbing (cars only lowered about 1 inch. If the rim would have been 8 inch or wider rubbing would have occurred when driving aggressively.
That statement doesn't mean anything unless you tell us what tire you were using.
The width of the wheel, for a given offset, will not affect where the tire is. THUS, whether the wheel is 7.5 or 8 doesn't matter. What matters is the TIRE width and WHEEL offset. (Of course the tire needs to fit the wheel.... no 295s on 7" wheels.)
Old 03-02-2006, 02:54 AM
SpitfireS's Avatar
neveronlines2k Posted on Mar 2 2006, 01:31 AM
The handling was affected enough for me to get rid of the wheels (ce28's) and buy some that fit better. Hope this helps. Good Luck
What handeling differences do you mean?
Heavier steering?
Low profile tire bumpier ride?
In my case the front track width changes +20mm and the rear +34mm if you go by the wheel centre.
Old 03-02-2006, 07:19 AM
VeilSide AP1's Avatar
Originally Posted by YZER,Mar 1 2006, 10:34 AM
I highly doubt you will rub at stock height. I am running 18x8 and 18x9 with +45 all around stock height and have had absolutely no rubbing issues. Here are some pics:
i am considering the similar set up and was curious, you have no rubbing issues but what if you wanna drop the car to make it look like this i know that he was running Front 18x8 225/40/18 and Rear 18x9.5 265/35/18 but dont know what offset that is, Anyone know? .....
Old 03-02-2006, 09:22 AM
spa-zz's Avatar
Scroll up. He mentioned the offset in his post.
Old 03-02-2006, 09:31 AM
Yea i saw that thanx but i was refering to the pic i posted, if anyone had an idea of what offset that might be
Old 03-02-2006, 09:37 AM
spa-zz's Avatar
Ummm. I'm confused. The pic you posted is the same one he posted. No?
blwn34
05-26-2014 08:40 PM
hadeediqbal10
09-09-2013 09:09 AM
Grendel
05-12-2008 05:42 PM
JAPCAB
10-23-2005 03:56 AM
m000240
07-08-2003 06:28 AM
Quick Reply: Offset-in-a-picture.
