offset and j
offset and j
i'm gonna buy 17'' wheels for my 03' s2k
the front ones are 17"x8j and the rear ones are 17"x 9j
can the 04' stock tires sizes (F 215/45 R 245/40) fit them?
and what is the proper offset?
Will it be ok if the front is +45 and the rear is +63??
plz do me a favor you adept guys..
FRONT - don't run the 225 wide tire..........especially if you are going to lower the car.....you'll rub (a lot)........you can get by with running a 215/45/17 in the front but the offset of +45 is a little low.
REAR - the offset that you have listed is great for the 9" wheel +63.... ..................you should be running a 255/40/17. This will fit perfectly....no issues lowered or not.
good luck....!!
good luck....!!
THANK YOU GUYS
that's what i wanted to know
so glad to hear everything is fine
by the way...could you tell me the specifications of the 04' OEM rims?(j number & offset)
vroooom247
07-30-2005 02:32 PM
