Offset Issue?
i believe the rear will fit no problem.
however, i think the concern here will be rubbing on the INSIDE in the front. using OEM ap1 wheels as a basis, the new wheels will extend about 4cm into the car. will this clear the front strut?
@RoosterS2: chances are at stock height you will not need fender work. you'll just have some good ol wheel gap.
It only hit the fender liner on turns. Some guys have pushed the liner away fromt the tires or trimed it. You could also go with a 245/40R17 front but then you can't rotate the tires and wheels. The rear is no problem.
If I can help let me know.
