offset help 17*9 +63 / 17*7.5 +45
215/45-17 fronts should be no prob, might want some camber... 265 rears or even 275 would fit, but much much better tire selection in 255/40-17 size.
Site Moderator
I suggest rolling the fronts with either 215 or 225 since you are lowering the car. Click the tips thread in my sig about rolling the fronts. Rears shouldn't need a roll. 215 or 225 front and 245 or 255 rear. No reason to go wider than a 255 tire on the rear as those are the correct sizes for the 9 inch wide wheel.
